製品情報にスキップ
1 1
AiM Taipan UC Bridge Tuner
SKU: C-UCB-T
通常価格
£520.00
通常価格
セールスプライス
£520.00
注文すべてでカーボンニュートラルな配送
The AiM Taipan UC Bridge Tuner is the connection between the CAN bus of the ECU and the USB port of your PC. This UC Bridge Tuner has been specifically designed to programme and configure an unprogrammed Taipan ECU.
Tuner licence Basic maps
Tuner License
If you purchase an unprogrammed Taipan ECU you will need this tuner to configure it. The Taipan ECU will able to be configured to any brand/model of bike
With this license, the tuner can create maps, configurations and strategies designed for the rider's bike. The tuner can flash then directly on the ECU or send an e-mail to allow the rider to download and install them in the ECU.
Taipan ECU Connections - Optional Extra
Below shows a functional diagram of products that can be added to the Taipan ECU:
AiM Taipan UC Bridge Tuner Technical Specifications and pinout
  • Connectors: n. 1 USB connection for PC
  • n. 1 JST 04R-JWPF-VSLE-S waterproof Connector for CAN Bus communication
  • Body: PA6 + 30% glass fiber
  • Dimensions: 103.5 x 45.3 x 18.1mm
  • Weight: 80g
  • 1 x Taipan UC Bridge Tuner
Taipan Video
Tuner License
  • Weight: 80g
Taipan Video
