AiM Solo & Solo 2 & Solo 2 DL Suction Cup Mount
SKU: SOLO-WM
- 通常価格
- £67.00
- 通常価格
- セールスプライス
- £67.00
- 単価
- あたり
+ VAT(英国のみ)
The AiM suction cup mount is suitable to fit the windscreen or a flat surface. Used to secure for Solo GPS lap timer to your car.
Secure mounting for GPS lap timer | Ball & socket for positioning |
Suitable for Solo, Solo 2 & Solo 2 DL | |
Suction Cup Mount for GPS Lap Timer
The AiM suction cup mount to suit the Solo, Solo 2 and Solo 2 DL has been designed to securely mount the Solo GPS lap timer to any flat surface such as your windscreen.
It has a 90mm locking and quick release suction cup, also a dual swivel joint making viewing angle adjustment quick and easy.
- 90mm arm
- Suction cup
- Clamp base with ball
- Locknut
- Screws and washers
- 1 suction cup Mount Bracket for Solo, Solo 2, Solo 2 DL
The AiM suction cup mount is suitable to fit the windscreen or a flat surface. Used to secure for Solo GPS lap timer to your car.Key Features :
The AiM suction cup mount to suit the Solo, Solo 2 and Solo 2 DL has been designed to securely mount the Solo GPS lap timer to any flat surface such as your windscreen.It has a 90mm locking and quick release suction cup, also a dual swivel joint making viewing angle adjustment quick and easy.
- 90mm arm
- Suction cup
- Locknut
![AiM Solo & Solo 2 & Solo 2 DL Suction Cup Mount - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMSolo_Solo2_Solo2DLSuctionCupMount_58ff52f7-790a-4669-a060-f42d71261f6c_1445x.png?v=1627480071)
![AiM Solo & Solo 2 & Solo 2 DL Suction Cup Mount - AimShop.com](http://www.aimshop.com/cdn/shop/products/Aim_Solo_2_Lap_Timer_Car_Windscreen_Suction_Cup_Mount_-_1600px_1445x.jpg?v=1627480071)
- 選択を選択すると、ページ全体が更新されます。
