AiM Solo 2 & Solo 2 DL Bar Pads
SKU: SOLO-PD-WB
- 通常価格
- £60.00
- 通常価格
- セールスプライス
- £60.00
- 単価
- あたり
Bar Pads For Solo 2 & Solo 2 DL
The AiM bar pads are designed to allow fitment of the Solo 2 & Solo 2 DL to the handlebars of a motocross bike.
Key Features:
These pads have been designed to allow the fitment of an AiM Solo 2 & Solo 2 DL to the handlebars of a motocross bike. The pads are shock-resistant and safe thanks to their polyurethane structure. Provides secure and reliable fitment of a Solo 2 & Solo 2 DL to a motocross bike. Able to withstand the tough forces of racing. Versions for this item for handlebars are with or without the cross brace. |
Please Note. The Solo is not included |
Not Enough Check Out Our Solo 2 DL & SmartyCams |
Bar pad with a brace
- Bar pad
- Transparent protection cover
- Mounting bracket
- 4 12mm M3 screws
- Installation guide
- Dimensions: 220x137.5x86.8mm
- Weight: 274g
Key Features:
Whats In The Box
- Bar pad
- Mounting bracket
- 4 12mm M3 screws
- Weight: 274g
- 選択を選択すると、ページ全体が更新されます。
