AiM Solo 2 DL GPS + ECU Car Track Day Lap Timer
SKU: SOLO2-K2
- 通常価格
- £630.00
- 通常価格
- セールスプライス
- £630.00
- 単価
- あたり
Direct ECU data logging
Predictive lap timing
Automatic track recognition
Internal 4 GB memory
Wi-Fi connection
10 configurable RGB LEDs
Choice of connection
The AiM Solo 2 DL 25Hz GPS lap timer is designed to be easy to use and provides accurate data for analysing your lap times. The device is equipped with a high-precision GPS receiver that can track your position on the track with accuracy. This allows you to see your exact racing line and compare it to optimal lines for faster lap times. A lot of users class this as the best track day lap timer as this also includes accelerometers and gyroscopes to track your car's movements and provide detailed data on acceleration, braking, and cornering forces.
One of the standout features of the AiM Solo 2 DL GPS lap timer is its ability to connect to your car's ECU to gather additional data. This allows you to monitor engine performance, coolant and oil temperatures, and other vital information that can help you fine-tune your driving technique. The lap timer can also display predictive lap times based on your current performance, giving you real-time feedback on how you are tracking against your previous best lap.
Another great advantage of the AiM Solo 2 DL GPS lap timer is its versatility. The device is designed to be compatible with a wide range of vehicles, from production cars to race cars. It can be easily mounted on your dashboard or windshield for easy visibility during your track sessions. The lap timer is also designed to be durable and withstand the rigours of track day racing, so you can focus on improving your lap times without worrying about the device failing.
Overall, the AiM Solo 2 DL GPS lap timer is a great tool for anyone looking to improve their track day performance. With its advanced features, accurate data tracking, and compatibility with a wide range of vehicles, this device can help you take your racing to the next level. Whether you are a beginner looking to shave seconds off your lap times, or a professional racer looking for that extra edge, the AiM Solo 2 DL GPS lap timer is a valuable tool to have in your arsenal.
Wi-Fi connection
- Display: Graphical
- GPS: 25 Hz
- External power: 12 V
- Memory: 4 GB
- Solo 2 DL
- Power cable with AC adapter
- User manual
