AiM SmartyCam HD 2.1 Display Glass Replacement Kit Motocross
SKU: SM-R-K2
- 通常価格
- £30.00
- 通常価格
- セールスプライス
- £30.00
- 単価
- あたり
+ VAT(英国のみ)
Replacement glass for the AiM SmartyCam HD 2.1 camera, providing anti-glare and scratch protection.
Fits SmartyCam HD 2.1 | Ideal replacement or spare |
Anti-scratch protection |
AiM SmartyCam HD 2.1 Glass Replacement Kit
The AiM glass replacement is an anti-glare, anti-scratch replacement lens to fit the SmartyCam HD 2.1 and is the same as supplied with the camera. The kit features Schott B270 glass and an O ring OR30X1.
It is ideal for replacing damaged protectors or for keeping as a spare.
It fits SmartyCam HD 2.1
Scratch-resistant
Anti-glare
Includes O ring seal and surround fixing screws
- Fits SmartyCam HD 2.1
- Scratch-resistant glass
- Anti-glare
- Includes O ring seal and surround screws
- Glass replacement Kit - For SmartyCam HD 2.1
Replacement glass for the AiM SmartyCam HD 2.1 camera, providing anti-glare and scratch protection.Key Features :
![](https://cdn.shopify.com/s/files/1/0214/9392/files/AiM_SmartyCam_HD_2.1_Glass_Methacrylate_Anti-Glare_Scratch_Protection_Motocross.png?v=1627900171)
The AiM glass replacement is an anti-glare, anti-scratch replacement lens to fit the SmartyCam HD 2.1 and is the same as supplied with the camera. The kit features Schott B270 glass and an O ring OR30X1.It is ideal for replacing damaged protectors or for keeping as a spare.
Scratch-resistant
Anti-glare
- Anti-glare
![AiM SmartyCam HD 2.1 Display Glass Replacement Kit Motocross - AimShop.com](http://www.aimshop.com/cdn/shop/products/Smarty_cam_2.1_Glass_The_kit_includes_the_Schott_B270_glass_and_his_O-ring_OR30X1_7d63659e-546e-4935-a93b-9ce5217739b9_1445x.jpg?v=1613142312)
- 選択を選択すると、ページ全体が更新されます。
