AiM SmartyCam HD 2.1 Lens Glass Replacement Kit Motocross
SKU: SM-R-K1
- 通常価格
- £30.00
- 通常価格
- セールスプライス
- £30.00
- 単価
- あたり
Replacement glass for the AiM SmartyCam HD 2.1 camera, providing anti-glare and scratch protection.
Fits SmartyCam HD 2.1 | Ideal replacement or spare |
Anti-scratch protection |
AiM SmartyCam HD 2.1 Glass Methacrylate Anti-Glare Scratch Protection
This lens protector is designed to fit the AiM SmartyCam HD 2.1 and is the same as supplied with the camera. They are manufactured from Methacrylate to provide anti-glare and scratch protection. Ideal for replacing damaged protectors or for keeping as a spare.
It fits Smartycam HD 2.1
Scratch-resistant
Anti-glare
Includes O ring seal
- Display Replacement Kit - Methacrylate anti-glare anti-scratch protection
- Display Glass Replacement Kit - For SmartyCam HD 2.1
Replacement glass for the AiM SmartyCam HD 2.1 camera, providing anti-glare and scratch protection.Key Features :
This lens protector is designed to fit the AiM SmartyCam HD 2.1 and is the same as supplied with the camera. They are manufactured from Methacrylate to provide anti-glare and scratch protection. Ideal for replacing damaged protectors or for keeping as a spare.It fits Smartycam HD 2.1
Scratch-resistant
Anti-glare
- 選択を選択すると、ページ全体が更新されます。
