製品情報にスキップ
1 2
AiM SmartyCam GP HD Bullet Cam U Bolt Mount 2.1 & 2.2 Offroad
SKU: SM-UB-GP-MX
通常価格
£80.00
通常価格
セールスプライス
£80.00
注文すべてでカーボンニュートラルな配送
The SmartyCam GP HD 2.1 & 2.2 (Bullet Camera) U bolt mount has been designed to hold and position the bullet camera.
Fits the SmartyCam GP HD camera Ball & socket adjustment system
Suitable for 0.5 to 1.2" bar For SmartyCam GP HD 2.1 & 2.2
The AiM SmartyCam GP HD U bolt mount is for mounting a SmartyCam GP HD 2.1 & 2.2 to your vehicle. The mount has been designed to mount to a roll bar, railing or tube that have a diameter of between 0.5 to 1.2".
The U bolt clamp has a unique ball and socket system which has been designed to cope with the rigours of motorsport.
U Bolt Mount
Securely attaches to any rollbar, railing or tube with a diameter of 0.5 to 1.2"
  • For use with SmartyCam GP HD 2.1 & 2.2
  • 60mm (2.36inches) arm
  • U bolt
  • 60mm arm
  • Ball head
  • Bullet cam bracket
Technical sheet Race Studio 3
U Bolt Mount
  • U bolt
  • 60mm arm
  • Ball head
