AiM SmartyCam GP HD 2.1 + 2.2 External Power Harness Kart
SKU: SM-EXP-K
- 通常価格
- £40.00
- 通常価格
- セールスプライス
- £40.00
- 単価
- あたり
AiM SmartyCam GP HD 2.1 & 2.2 External Power Harness
The AiM SmartyCam GP HD 2.1 & 2.2 external power harness can be used to be connected to an external battery.
Suitable for SmartyCam GP HD 2.1 & 2.2 | External power cable 12V |
712 - 7 pins connector | Two free wires |
The power lead fits the SmartyCam and the two un-terminated free wires will connect to a 12V battery.
The cable length is 2m.
- SmartyCam GP HD 2.1 & 2.2 External Power Harness
- Allows external battery connection 12V
- 712 - 7 pin male connection
- Cable length: 2m
- 1 x SmartyCam GP HD 2.1 & 2.2 External Power Harness
The AiM SmartyCam GP HD 2.1 & 2.2 external power harness can be used to be connected to an external battery.Key Features :
The AiM SmartyCam GP HD 2.1 & 2.2 external power harness can be used to be connected to an external battery.The power lead fits the SmartyCam and the two un-terminated free wires will connect to a 12V battery.
- Cable length: 2m
- 選択を選択すると、ページ全体が更新されます。
