製品情報にスキップ
1 1
Car Potentiometer Replacement Rose End Fitting
SKU: CASUS-POT-END-RJ
通常価格
£8.50
通常価格
セールスプライス
£8.50
注文すべてでカーボンニュートラルな配送
Replacement rose end joint fitting for the suspension potentiometer.
Replacement rose end fitting Spare or replacement parts
The Potentiometer rose joint fitting is a replacement part to fit the suspension potentiometer used to measure displacement between two points using a sensor.
Use as a replacement or spare part.
One Potentiometer Rose End Fitting Replacement Supplied.
  • Replacement Potentiometer Rose End Fitting
  • 1 x Rose End Fitting Potentiometer Replacement Fitting
