AiM Motocross Suzuki Solo 2 DL Plug & Play Lead
SKU: SUZ-MX-PP
- 通常価格
- £67.00
- 通常価格
- セールスプライス
- £67.00
- 単価
- あたり
The AiM ECU plug & play cable has been specifically designed for Suzuki bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.
Suzuki plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for Solo 2 DL |
Suzuki Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Suzuki bikes. This plug & play cable can be used for the Solo 2 DL.
RMZ 250cc 4-stroke - 2010-2013 | RMZ 450cc 4-stroke - 2008-2013 |
Example data protocols
- Below is a pinout drawing for the Suzuki Solo 2 DL plug & play connection cable
- Suzuki Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for Suzuki bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Suzuki bikes. This plug & play cable can be used for the Solo 2 DL.The cable is an easy fitment to your bike and allows ECU data to be logged.
The plug & play cable currently fits the following Suzuki bike models:RMZ 250cc 4-stroke - 2010-2013 | RMZ 450cc 4-stroke - 2008-2013 |
Example data protocols sampled include RPM, Throttle position, Lambda value, Air temperature, Engaged gear, Battery supply Map switch and many more. Refer to the technical sheet in the Downloads Tab for an extensive protocol list.Expand Your System
- 選択を選択すると、ページ全体が更新されます。
