M10 VDO Pressure Sensor 0-10 Bar 0-145 PSI
SKU: S-P-O-VDO-10
- 通常価格
- £190.00
- 通常価格
- セールスプライス
- £190.00
- 単価
- あたり
+ VAT(英国のみ)
The AiM VDO Pressure sensor for pressure readings of fluids such as oil and gasoline. Please do not use it to measure brake pressure.
0-10 Bar (0-145 PSI) | 4 pins 719 male binder |
The VDO Pressure sensor for pressure readings of fluids such as oil and gasoline. Please do not use it to measure brake pressure. It needs careful installation.
The 0-10 bar sensor is made of a cylinder – with M10*1 thread that has to be fixed directly to the engine block – and two connectors that are for GND and pressure signals. If the engine thread is more significant than the cylinder thread, AiM suggests using joints. AiM recommends you tightly screw the sensor to the engine so that vibrations do not loosen it.
The VDO sensor cable ends with a four pins Binder 719 male connector. Between pins 1 and 4 of the connector is mounted a 1,8 kΩ resistor. AiM recommends not to tamper with the sensor, or it will not work.
The sensor comes with a 45cm cable as standard. You will most likely need a custom patch lead to suit your wiring specifications.
- Working Range: 0-10 Bar
- Output Signal: 0-5V
- Sensor Thread: M10*1
- Cable Length: 450mm
- Connection: 4 pins 719 male Binder
- Two flying cables
- VDO Pressure Sensor 0-10 bar (0-145 PSI)
The AiM VDO Pressure sensor for pressure readings of fluids such as oil and gasoline. Please do not use it to measure brake pressure.Key Features :
The sensor comes with a 45cm cable as standard. You will most likely need a custom patch lead to suit your wiring specifications.MXS / MXP / MXG / MXL (Strada and Pista) / MXL2 / EVO5 / MXm etc harnesses are fitted with 719 connections. To extend the length between your dash display/logger and the analogue sensor, please use the 719 - 719 patch lead, which is available in various lengths from 0.5 - 3 metres. For most installations, you will need one of these leads.
- Two flying cables
![AiM M10 VDO Pressure Sensor 0-10 Bar 0-145 PSI - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMM10VDOPressureSensor0-10Bar0-145PSI2_9d307353-8700-401f-80f9-b8db14c13c77_1445x.png?v=1627045554)
![AiM M10 VDO Pressure Sensor 0-10 Bar 0-145 PSI - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMM10VDOPressureSensor0-10Bar0-145PSI_1445x.png?v=1627045554)
![AiM M10 VDO Pressure Sensor 0-10 Bar 0-145 PSI - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMM10VDOPressureSensor0-10Bar0-145PSI1_1445x.png?v=1627045554)
![AiM M10 VDO Pressure Sensor 0-10 Bar 0-145 PSI - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMM10VDOPressureSensor0-10Bar0-145PSI2_1445x.png?v=1627045554)
- 選択を選択すると、ページ全体が更新されます。
