製品情報にスキップ
1 3
AiM Hall Speed Pick Up Sensor 719 Plug 2m Cable
SKU: S-S-H719
通常価格
£70.00
通常価格
セールスプライス
£70.00
注文すべてでカーボンニュートラルな配送
Hall effect wheel speed sensor 719 plastic connector
2m cable M8 thread
719 Connection to suit MXL (Strada and Pista), MXG/MXS/MXP (inc Strada), MXL2. Use a 719-719 Patch Lead to extend to the required length.
2m cable M8 thread
The sensor consists of a thin piece of metal that passes a continuous current through it. When the sensor is placed in a magnetic field the electrons move to one side of the metal and protons move to the other side of the plate. You will then be able to get a voltage. The Hall Effect Sensor is a non-contact device that needs a metallic trigger to pass in front of it. Again, a bracket will usually need to be fabricated to mount the sensor in a suitable position. Please ensure that the distance between the sensor and trigger is in a 0.5 – 2.0 mm (0.007-0.07 inches) range.
  • 719 plug Binder Connector
  • Power Supply: 10-30 VDC
  • Sensor Thread: M8
  • Waterproof: IP67
  • 1 x Hall Effect Speed Sensor 719 Plastic connector 2m Cable
