AiM EXP Cable for PDM 1.5m
SKU: PDM-EXP
- 通常価格
- £40.00
- 通常価格
- セールスプライス
- £40.00
- 単価
- あたり
The AiM pre-assigned expansion cable for the PDM has 6 pre-assigned cable connections and a 712 5 pin Binder connector.
PDM expansion cable | Six cable connections |
712 5 pin Binder connector | 1.5m cable |
Cable length: 1.5m
- EXP cable for PDM
- 6 Pre-assigned expansion port
- 712 5 pin Binder connector
- 1.5m cable
- 1 x EXP cable for the PDM
The AiM pre-assigned expansion cable for the PDM has 6 pre-assigned cable connections and a 712 5 pin Binder connector.Key Features :
The AiM pre-assigned expansion cable for the PDM has 6 pre-assigned cable connections and a 712 5 pin Binder connector.Cable length: 1.5m
- EXP cable for PDM
- 1.5m cable
- 選択を選択すると、ページ全体が更新されます。
