Branded Classic Cap
SKU: C-C
- 通常価格
- £20.00
- 通常価格
- セールスプライス
- £20.00
- 単価
- あたり
+ VAT(英国のみ)
Accelerate Your Style
Shift into High Gear with an Edge
Rev up your style with our navy blue, high-octane cap - the perfect gear for any motorsport enthusiast.
From the racetrack to the garage, this cap is designed to keep you looking and feeling your best. With its durable fabric and adjustable strap, it can handle the toughest of conditions and provide a comfortable fit for long days at the track.
The embroidered logo adds a touch of style, while the breathable mesh panels ensure maximum airflow to keep you cool under pressure.
Whether you're hitting the throttle or wrenching on your ride, this cap has got you covered.
We have two styles available, Classic Cap has our circular Aim logo on the cap's peak and on the back, and our AimShop Cap has the AimShop logo on the peak and on the back.
Maintenance
100% Cotton
Hand Wash & Air Dry
Curved peak
Stylish, embroidered logo
Adjustable head strap
Two options available
Maintenance
100% Cotton
Hand Wash & Air Dry
Curved peak
![]() T-Shirts |
![]() Hoodies |
![]() Shop Cap |
![AiM Branded Classic Cap - AimShop.com](http://www.aimshop.com/cdn/shop/files/2_08bb19b4-cd66-420a-bbde-b4621c9a7d42_1445x.png?v=1683711646)
![AiM Branded Classic Cap - AimShop.com](http://www.aimshop.com/cdn/shop/files/1_100c10d1-ec05-422d-a3a4-8b1d2b6cf318_1445x.png?v=1683711646)
![AiM Branded Classic Cap - AimShop.com](http://www.aimshop.com/cdn/shop/files/4_6f73a15d-bc64-4694-869b-1814f668b779_1445x.png?v=1683643751)
![AiM Branded Classic Cap - AimShop.com](http://www.aimshop.com/cdn/shop/files/6_98a4e4a1-44ca-48e3-a8dd-859df685ce3f_1445x.png?v=1683643752)
![AiM Branded Classic Cap - AimShop.com](http://www.aimshop.com/cdn/shop/files/7_b7979e66-6754-41ad-afec-ad839a350904_1445x.png?v=1683643750)
![AiM Branded Classic Cap - AimShop.com](http://www.aimshop.com/cdn/shop/files/9_9d7e9243-14dc-4e8e-9362-f7af55cff408_1445x.png?v=1683643750)
- 選択を選択すると、ページ全体が更新されます。
