90 Degree Bolt-on for Dash Bracket
SKU: UP-90-TAB
- 通常価格
- £8.00
- 通常価格
- セールスプライス
- £8.00
- 単価
- あたり
Bolt on 90 Degrees Dash Mount bracket Tab
A simple bolt/screw on bracket to facilitate our dash mounts.
Key Features:
90-Degree Bolt on for Dash Bracket
A simple bolt/screw on bracket to facilitate our modular dash/button mounts. |
AiM Technologies are committed to supplying, professional engineers quality Motorsport products. Our cables and accessories are well-engineered and designed for demanding Motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the market place today. |
Unlock your potential |
AiM 90-Degree Bolt-on for Dash Bracket
Key Features:
A simple bolt/screw on bracket to facilitate our modular dash/button mounts. 2mm Stainless bent at 90 degrees Our Modular Steering Wheel Components are Stainless Steel (raw finish) interchangeable components to facilitate the mounting of displays/buttons/dash/lap timers/shift lights. |
Whats In The Box
- 選択を選択すると、ページ全体が更新されます。
