AiM 16 Pin AMP Plug and Pins for MXL Strada and Pista
SKU: P-AMP-16-5CND1740462
- 通常価格
- £10.00
- 通常価格
- セールスプライス
- £10.00
- 単価
- あたり
The AiM 16 AMP plug & pins are ideal if you need a replacement or keep them as spares.
Suitable for MXL Strada & Pista | 16 pins, One plug |
Ideal for replacement or spares | |
These plugs & pins are suitable for MXL Strada & Pista.
- AMP Plug
- 16 Pins
- AiM 16 Pin AMP Plug & Pins for MXL Strada & Pista
The AiM 16 AMP plug & pins are ideal if you need a replacement or keep them as spares.Key Features :
The AiM 16 AMP plug & pins are ideal if you need a replacement or keep them as spares.These plugs & pins are suitable for MXL Strada & Pista.
- AMP Plug
- 16 Pins
- 選択を選択すると、ページ全体が更新されます。
