製品情報にスキップ
1 1
AiM 14 Pin Strada 1.2 CAN Harness for MXS, MXP, MXG Motorcycle
SKU: MX-S-L-CAN-V02573320
通常価格
£160.00
通常価格
セールスプライス
£160.00
注文すべてでカーボンニュートラルな配送
The AiM 14 pin CAN connector harness is a standard replacement for the Strada MXS, MXP, MXG (MX series) dash displays.
Fits MXS, MXG, MXG dashes Replacement for original wiring
 14 pin AMP female connector 4 pin binder 719 female
 5 pin binder 712 female
14 Pin AMP CAN Harness
The AiM 14 pin Strada 1.2 AMP connector with CAN connector is a standard replacement for the MXS, MXG, MXP (MX Series) dash displays.
With pre-wired connectors for easy connectivity. A 14 pin AMP female connector, 4 pins Binder with 719 female connectors, 5 pins Binder 712 female connector and 5 cables.
  • 14 pin AMP connector flying connector
  • 4 pins Binder 719 female connector
  • 5 pins Binder 712 female connector
  • X5 1 x 0.5 cables
  • 14 pin Strada 1.2 CAN Harness
  • X5 1 x 0.5 cables
