製品情報にスキップ
1 4
Suzuki AiM Solo 2 DL Motocross Plug & Play Lap Timer Kit
SKU: SOLO2-K-SUZ-MX-PP
通常価格
£535.00
通常価格
セールスプライス
£535.00
注文すべてでカーボンニュートラルな配送
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for Suzuki bikes this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide Suzuki ECU connection cable
This kit has been specifically designed for Suzuki bikes. The kit comes with a cable for your bike. Connecting the Solo 2 DL to your bike's ECU will give you all the engine performance information you need to help improve your driving performance.
Suzuki RMZ 250cc - 4 stroke - 2010-2013 Suzuki RMZ 450cc - 4 stroke - 2008-2013
The Suzuki ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Data Recall On Screen
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
Below is the pinout drawing for the Suzuki plug & play connection cable.
  • Solo 2 DL
  • Power cable with AC adapter
  • User manual
  • AiM Suzuki Connection Cable
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • Solo 2 DL
  • User manual
