製品情報にスキップ
1 1
Super B Nomia 12V210AH Lithium Traction Battery
SKU: SB-E-210
通常価格
£2,515.00
通常価格
セールスプライス
£2,515.00
注文すべてでカーボンニュートラルな配送
superb lithium batteries
The Super B Nomia 12V210Ah is a Lithium Iron Phosphate battery (LiFePO4) with a rated capacity of 210Ah. The unique combination of state-of-the art technology and smart software makes this lithium battery a robust, safe and easy to use energy storage solution. Compared to conventional lead-acid batteries, the Super B Nomia 12V210Ah lithium battery offers an enormous weight and space saving. It is very efficient, has extremely high performances and is maintenance free.
  • Product Features
  • Traction battery
  • Lithium Iron Phosphate (LiFePO4): Safe Li-ion technology
  • Integrated BMS (Battery Management System), external disconnect device needed
  • Glass fiber reinforced plastic (GRFP) Casing, Aluminum / PE sandwich side panels
  • Terminals for 2 x M8 bolts
  • Integrated fuse, 32V / 500A
  • Wired communication interface: CANopen
  • Battery monitoring / History Storage
  • Adaptive cell balancing
  • Configurable in serial or parallel connection
  • Output for bistable relay / latching relay
Intended Use
The Nomia 12V210Ah/12V340Ah Li-ion battery serves as a energy source of 12V in power systems for recreational vehicles, commercial vehicles, leisure boats, commercial vessels and stationary applications. Potential applications of this Li-ion battery include: off grid power supply, marine power supply, medium for (renewable) energy storage and (traction) battery for vehicles.Use as a starter battery is not possible. Up to 4 batteries can be connected in series or in parallel to increase the total capacity up to 840Ah or 1360Ah. For more batteries in series or parallel always consult with Super B.
PERFORMANCE
Low maintenance
Fast charging
Safest lithium technology
High discharge currents
High capacity
Low weight
High cycle count
Low self-discharge
CERTIFICATIONS
UN38.3 UN38.3 UN38.3 UN38.3 UN38.3 UN38.3 UN38.3
3 Year Warranty
A 3-year warranty offers the best peace of mind. It is the benefit of years of continuous engineering improvement and proven experience with all of our batteries in the harshest environments.
3 year warranty
The Super B Nomia 12v210ah Lithium Traction Battery is a cutting-edge lithium battery designed for use in electric vehicles, golf carts, forklifts, and other traction applications. With a capacity of 210 amp hours and a voltage of 12 volts, this battery offers superior performance and reliability compared to traditional lead-acid batteries.
One of the key advantages of the Super B Nomia 12v210ah Lithium Traction Battery is its lightweight and compact design. Weighing just a fraction of what a traditional lead-acid battery weighs, this lithium battery is much easier to handle and install, making it ideal for applications where space and weight are at a premium. Additionally, the Super B Nomia battery has a long cycle life, with the ability to withstand thousands of charge and discharge cycles without losing capacity.
Another important feature of the Super B Nomia 12v210ah Lithium Traction Battery is its fast charging capabilities. With a high charge acceptance rate, this battery can be recharged quickly, reducing downtime and allowing for more efficient use of the equipment it powers. This makes the Super B Nomia battery an excellent choice for applications that require frequent and rapid charging.
ELECTRICAL SPECIFICATIONS
Nominal capacity
210Ah
Open circuit voltage
13.2v
self-discharge
<3% per month
Cycle Life
>>3500 cycles (at 1C charge/ discharge, 100% DoD)
Voltage
12v
MECHANICAL SPECIFICATIONS
Dimensions (LxWxH)
417 x 227 x 314 mm / 16.4” x 8.9” x 12.4”
Weight
23kg / 50.7lbs
Case material
GFRP
Ingress protection
IP50
Cell type / Chemistry
Prismatic - LiFePO4
Charge method
CCCV
Charge voltage
14.3V - 14.6V
Max. charge current
210A
End of discharge voltag
10V
Discharge current continuous
500A
Discharge pulse current
800A (10 sec)
TEMPERATURE SPECIFICATIONS
Charge temperature
0°C to 55°C / 32°F to 131°F
Discharge temperature
-20°C to 55°C / -4°F to 131°F
Storage temperature
-20°C to 45°C / -4°F to 113°F
COMPLIANCE SPECIFICATIONS
Certifications
CE, FCC, UN 38.3, UN ECE R10.06, UL 1642 (Cells), EN/IEC 62619-62620 (ES-TRIN), RINA Type Approval
Shipping classification
UN 3480
GENERAL SPECIFICATIONS
EAN-13
8718531361645
Battery designation
IFpP/36/130/195/ [2P4S]M/-20+55/95
Available to download Here
superb app
  • Product Features
  • Traction battery
Intended Use
PERFORMANCE
Low maintenance
Fast charging
High capacity
Low weight
High cycle count
Low self-discharge
CERTIFICATIONS
3 Year Warranty
3 year warranty
Specifications
Nominal capacity
210Ah
13.2v
self-discharge
<3% per month
Cycle Life
Voltage
12v
Dimensions (LxWxH)
Weight
23kg / 50.7lbs
Case material
GFRP
Ingress protection
IP50
Prismatic - LiFePO4
Charge method
CCCV
Charge voltage
14.3V - 14.6V
Max. charge current
210A
10V
500A
800A (10 sec)
Charge temperature
Storage temperature
Certifications
UN 3480
EAN-13
8718531361645
Battery designation
Quickstart Guide
Mobile App
superb app
