製品情報にスキップ
1 4
MV Agusta F3 & F4 AiM Solo 2 DL Plug & Play Lap Timer Kit
SKU: SOLO2-K-MV-V02569310-X47SOLO2DL02
通常価格
£710.00
通常価格
セールスプライス
£710.00
注文すべてでカーボンニュートラルな配送
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the MV Agusta this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide MV Agusta ECU connection cable
This kit has been specifically designed for MV Agusta bikes. The kit comes with a cable for your bike. Connecting the Solo 2 DL to your MV Agusta ECU will give you all the engine performance information you need to help improve your driving performance.
The plug & play cable currently fits the following MV Agusta bike models:
F3 675 - From 2012 F3 800 - From 2012
F4 1000 - From 2013
The MV Agusta ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Data Recall On Screen
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
Below is the pinout drawing for the MV Agusta plug & play connection cable.
  • Solo 2 DL
  • Power cable with AC adapter
  • User manual
  • AiM MV Agusta Connection Cable
F4 1000 - From 2013
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • Solo 2 DL
  • User manual
