Link XS Expansion Loom #XSL
SKU: XSL
- 通常価格
- £35.00
- 通常価格
- セールスプライス
- £35.00
- 単価
- あたり
Want to add additional inputs/output to your Link Plugin ECU? Use the XS Loom. The Link XS Loom plugs into the expansion connector on all Link G4, G4+ and G4X plug-in ECUs.
The number of extra inputs and outputs added by the XS Loom is dependent on the Plugin ECU. For specific details check the plug-in ECUs specifications.
Common applications include but are not limited to:
Boost adjustment knob or switch
Wide-band AFR/Lambda
Oil Pressure Sensor
Fuel Pressure Sensor
Inlet Air Temperature (IAT) sensor
Map switch (Different tunes available via toggle switch)
The XS Loom is 2.5m long and uses 20AWG wire.
- XS Loom 2.5m
Want to add additional inputs/output to your Link Plugin ECU? Use the XS Loom. The Link XS Loom plugs into the expansion connector on all Link G4, G4+ and G4X plug-in ECUs.The number of extra inputs and outputs added by the XS Loom is dependent on the Plugin ECU. For specific details check the plug-in ECUs specifications.
Boost adjustment knob or switchWide-band AFR/Lambda
Oil Pressure Sensor
- XS Loom 2.5m
- 選択を選択すると、ページ全体が更新されます。
