Link "B" Loom Medium - #2LB
SKU: 2LB
- 通常価格
- £140.00
- 通常価格
- セールスプライス
- £140.00
- 単価
- あたり
+ VAT(英国のみ)
2.5 m long 'B' loom to suit G4, G4+ and G4X ECUs
Perfect for all custom wiring jobs utilising Link WireIn ECUs. The ‘B’ Loom has a Link ‘B’ ECU connector at one end and unterminated wires at the other. All wires are colour coded to match the manual. This loom is also available in 0.4m and 5m lengths.
Added features of 2.5m and 5m ‘B’ Looms include:
-Shielded Dual-Core wires for knock signals
Suitable Applications:
Link G4X Storm (Loom A also required)
Link G4X and G4+ Fury (Loom A also required)
Link G4X, G4+ and G4 Xtreme (Loom A also required)
Link G4+ Thunder (Note: Loom A and connector kits C and D may also be required)
Link G4+ Storm Black (Loom A also required) – Note: Loom B is not required for the older Silver or Blue G4 or G4+ Storm models
Vipec V88 (Loom A also required)
Vipec i88 (Loom A also required)
- "B" Loom Medium 2.5m
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Link_Banner_Description.png?v=1616071775)
2.5 m long 'B' loom to suit G4, G4+ and G4X ECUsPerfect for all custom wiring jobs utilising Link WireIn ECUs. The ‘B’ Loom has a Link ‘B’ ECU connector at one end and unterminated wires at the other. All wires are colour coded to match the manual. This loom is also available in 0.4m and 5m lengths.
Link G4X Storm (Loom A also required)Link G4X and G4+ Fury (Loom A also required)
![Link "B" Loom Medium - #2LB - AimShop.com](http://www.aimshop.com/cdn/shop/products/Link_B_LoomMedium-_2LB_1445x.png?v=1616412678)
![Link "B" Loom Medium - #2LB - AimShop.com](http://www.aimshop.com/cdn/shop/products/Link_B_LoomMedium-_2LB2_1445x.png?v=1616412678)
![Link "B" Loom Medium - #2LB - AimShop.com](http://www.aimshop.com/cdn/shop/products/Link_B_LoomMedium-_2LB3_1445x.png?v=1616412678)
- 選択を選択すると、ページ全体が更新されます。
