Link Nissan 350ZLink - N350X PlugIn ECU
SKU: N350X
- 通常価格
- £1,195.00
- 通常価格
- セールスプライス
- £1,195.00
- 単価
- あたり
Easy to install. Affordable. Reliable
This ECU comes in its own enclosure, while the installation is a breeze with no alteration of the factory wiring loom required for the models listed below.
The N350X ECU is designed to suit the VQ35DE engine.
This ECU works with manual AND automatic transmissions.
ECU includes an onboard 4 bar or 7 bar MAP sensor.
Check the features tab for I/O expansion options
Highly recommended to fit an IAT sensor.
Suitable Applications:
2002 to 2006 Nissan 350Z (Fairlady Z Z33)
2003 to 2006 Nissan Skyline V35
2003 to 2006 Infinity G35
PlugIn Key Features:
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
Expansion connector 1
Gnd Sensor Ground Only
+5V Low Current +5V Supply
Aux 15 Auxiliary Output
Aux 14 Auxiliary Output
DI 8 Digital Input
DI 9 Digital Input
An Volt 8 Analog 0-5V input
Expansion connector 2
DI 11 Digital Input
Aux 16 Auxiliary Output
Aux 8 Auxiliary Output
- G4X PlugIn ECU
- Stickers
Easy to install. Affordable. ReliableG4X PlugIn ECUs offer the latest in engine management technology, designed to easily maximize the potential of your car.
2002 to 2006 Nissan 350Z (Fairlady Z Z33)2003 to 2006 Nissan Skyline V35
CAN port
Staged injection
The following expansion connector inputs/outputs are provided:Expansion connector 1
DI 8 Digital Input
DI 9 Digital Input
DI 11 Digital Input
- G4X PlugIn ECU
- Stickers
- 選択を選択すると、ページ全体が更新されます。
