製品情報にスキップ
1 5
Ducati Panigale Solo 2 DL & SmartyCam 3 GP Track Day Kit
SKU: SM-CAM-GP-2-SOLO2-K-DUC-1-SM-GPC
通常価格
£2,210.00
通常価格
セールスプライス
£2,210.00
注文すべてでカーボンニュートラルな配送
Ducati Panigale AiM Solo 2 DL & SmartyCam 3 GP Motorcycle Plug & Play Lap Timer Track Day Kit
The Ducati Panigale plug & play kit combined with the Solo 2 DL and SmartyCam 3 GP gives you the ultimate track day experience.
Automatic track recognition 712 male connector - 7 pin
Database with more than 4,000 tracks worldwide Ducati Panigale ECU connection cable
This ultimate track day kit has been specifically designed for Ducati Panigale bikes. The kit includes a plug & play interface cable and bracket for your bike. A Solo 2 DL to give you the most precise lap times and the incredibly robust SmartyCam 3 GP to record your races and provide all the technical layovers to help improve your performance. Also added is our 3 GP bullet camera clamp mount to enable you to position the bullet camera on your bike. Connecting the Solo 2 DL to your Ducati Panigale ECU will give you all the engine performance information you need to help improve your driving performance.
SmartyCam 3 GP Features:
The plug & play cable currently fits the following Ducati Panigale bike models:
899 Panigale - 2013-2015 959 Panigale - From 2016
1199 Panigale - 2012-2014 1199R Panigale - 2015-2017
1299 Panigale - 2015-2019
Powerful Combination
The Ducati Panigale ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
SmartyCam 3 GP
Automatic Start/Stop
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
  • SmartyCam 3 GP
  • CMOS sensor: Global Shutter
  • Video Out: 3G-SDI
  • External power: 9-15 Volt
  • Connectors: 1 Deutsch 22 pin + 1 SMA SDI Video out + 2 SMA bullet connection + 1 USB-C
  • Auto Power ON: Yes
  • Auto Power OFF: Yes
  • Body: Anodised Aluminium
  • Waterproof: IP65
Below is the pinout drawing for the Ducati Panigale plug & Play connection cable.
  • Solo 2 DL
  • Power cable with AC adapter
  • SmartyCam 3 GP - Bullet Cam
  • External CAN cable 2m
  • External power cable
  • Ducati Panigale Plug & Play connection cable
  • Bracket
  • 1 washer
  • 1 rubber dowel
SmartyCam 3 GP
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • SmartyCam 3 GP
  • Video Out: 3G-SDI
  • Waterproof: IP65
  • Solo 2 DL
  • Bracket
  • 1 washer
  • 1 rubber dowel
