Ducati Multistrada 1200 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable
SKU: DUC-PP
- 通常価格
- £67.00
- 通常価格
- セールスプライス
- £67.00
- 単価
- あたり
+ VAT(英国のみ)
Ducati Multistrada 1200 AiM Solo 2 DL & EVO4S Plug & Play Cable
The AiM ECU plug & play cable has been specifically designed for the Ducati Multistrada bike. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.
Ducati Multistrada plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for Solo 2 DL & EVO4S Data Logger |
Ducati Multistrada Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Ducati Multistrada bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.
The plug & play cable currently fits the following Ducati Multistrada bike model:
![](https://cdn.shopify.com/s/files/1/0214/9392/files/1200_Ducati_Multistrada_Bike.png?v=1620404780)
Multistrada 1200 - 2010-2011 |
Example data protocols
- Below is a pinout drawing for the Ducati Multistrada plug & play connection cable
- Ducati Multistrada Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for the Ducati Multistrada bike. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Ducati Multistrada bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.The cable is an easy fitment to your bike and allows ECU data to be logged.
The plug & play cable currently fits the following Ducati Multistrada bike model:![](https://cdn.shopify.com/s/files/1/0214/9392/files/1200_Ducati_Multistrada_Bike.png?v=1620404780)
These are some of the items that can be added to your bike for incrementing performance and data. ![]() |
![Ducati Multistrada 1200 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable - AimShop.com](http://www.aimshop.com/cdn/shop/products/DucatiMultistrada1200AiMSolo2DL_EVO4SPlug_PlayCablenew_1445x.png?v=1620811023)
![Ducati Multistrada 1200 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable - AimShop.com](http://www.aimshop.com/cdn/shop/products/DucatiMultistrada1200AiMSolo2DL_EVO4SPlug_PlayCable2_1445x.png?v=1620811023)
- 選択を選択すると、ページ全体が更新されます。
