Ducati 848, 1098, 1198 AiM Solo 2 & Solo 2 DL Motorcycle Bracket
SKU: DUC-2-B
- 通常価格
- £60.00
- 通常価格
- セールスプライス
- £60.00
- 単価
- あたり
The AiM Ducati motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.
Ducati bracket | All necessary mounting hardware |
Suitable for Solo 2 & Solo 2 DL | |
Ducati Solo 2 & Solo 2 DL Bracket
The Ducati 848, 1098, 1198 bracket has been designed to provide a simple and secure way for mounting your Solo 2 or Solo 2 DL GPS Lap Timer on to your bike.
Please Note: If you are unsure this bracket will fit your bike, don't hesitate to contact one of our team. Either by email, phone or online chat.
Also available is our Ducati plug & play cable for the following bike models: (Sold Separately)
848 Base/EVO/EVO Corse - 2007-2013 | 1098 Base/S/S Tricolore/R - 2007-2009 |
1198 Base/S/S Corse/R Corse/SP - 2009-2011 |
Example data protocols
- Specifically designed Ducati 848, 1098, 1198 bracket for the Solo 2 and Solo 2 DL
- 1 Bracket
- 2 self-locking nuts
The AiM Ducati motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.Key Features :
The Ducati 848, 1098, 1198 bracket has been designed to provide a simple and secure way for mounting your Solo 2 or Solo 2 DL GPS Lap Timer on to your bike.Our brackets are supplied with all the necessary hardware required for fitting to your bike.
Also available is our Ducati plug & play cable for the following bike models: (Sold Separately)848 Base/EVO/EVO Corse - 2007-2013 | 1098 Base/S/S Tricolore/R - 2007-2009 |
- 1 Bracket
- 選択を選択すると、ページ全体が更新されます。
