AiM Taipan Universal Patch Lead
SKU: C-UCB-P-2
- 通常価格
- £40.00
- 通常価格
- セールスプライス
- £40.00
- 単価
- あたり
The AiM Taipan universal extension cable has been specifically designed to allow connection of various ancillary systems to the Taipan ECU.
UC bridge extension cable |
2m or 4m length |
Handlebar Switch extension cable |
2m or 4m length |
AiM Taipan Accessories
The AiM UC Bridge extension cable has been manufactured to connect the Taipan ECU to the UC bridge and/or the Handlebar Switch
The patch lead is connected to the JST connector on the Taipan ECU and is available in two lengths 2m or 4m.
UC Bridge - Optional Extra
User License:
A Taipan ECU comes with some basic maps that already give you better performance than the stock maps. Highly professional tuners all over the world offer specific maps that better fit your requirements, managing, for example, different exhaust, two injectors etc.
The UC Bridge is required for two functions:
Tuner License:
*Please Note: For information regarding the UC-Bridge Tuner, Please contact one of our Aim technical team for further information.
Taipan ECU Connections - Optional Extra
- UC Bridge and/or Handlebar Switch extension cable
- Length: 2m or 4m lengths available
- Connects from Taipan ECU to UC Bridge and Handlebar Switch
- JST Connector - 04R-JWPF-VSLE-S
- Universal Patch Lead in 2m or 4m lengths available at checkout
The AiM Taipan universal extension cable has been specifically designed to allow connection of various ancillary systems to the Taipan ECU.Key Features :
2m or 4m length |
2m or 4m length |
User License:
Tuner License:
Video
- 選択を選択すると、ページ全体が更新されます。
