AiM Solo External 3 Pin Power Lead & Lighter Socket Plug
SKU: SOLO-EXP-L
- 通常価格
- £42.00
- 通常価格
- セールスプライス
- £42.00
- 単価
- あたり
The AiM 3 pin power lead with 12V lighter socket plug for the Solo GPS lap timer.
3 pin - 712 male binder connection | 12V car lighter plug |
Suitable for Solo GPS lap timer | |
Solo External Power Cable
The AiM external power cable to suit the AiM Solo GPS Lap Timer. Has a 3 pin Binder 712 male connector on one side and a 12V car lighter plug on the other side.
Suitable for spares, in a second vehicle, or to replace a lost or damaged lead.
The AiM 3 pin power lead with 12V lighter socket plug for the Solo GPS lap timer.Key Features :
The AiM external power cable to suit the AiM Solo GPS Lap Timer. Has a 3 pin Binder 712 male connector on one side and a 12V car lighter plug on the other side. Suitable for spares, in a second vehicle, or to replace a lost or damaged lead.Expand Your System
- 3 pin - 712 male binder connection
- 2m Cable
- 12v car lighter plug
- Solo 3 pin power lead & 12V car lighter plug
