AiM SmartyCam GP HD Bullet Cam Roll Cage Mount 2.1 & 2.2
SKU: SM-VB-GP
- 通常価格
- £80.00
- 通常価格
- セールスプライス
- £80.00
- 単価
- あたり
+ VAT(英国のみ)
Clamp to a wide range of diameter tubing | For SmartyCam GP HD 2.1 & 2.2 |
Roll Cage Mount
- Handlebar bracket
- 60mm arm
- Ball head
- Bullet cam bracket
The SmartyCam GP HD 2.1 & 2.2 (Bullet Camera) roll cage mount has been designed to hold and position the bullet camera.Key Features :
![](https://cdn.shopify.com/s/files/1/0214/9392/files/AiM_SmartyCam_GP_HD_Bullet_Cam_Roll_Cage_Mount_2.1_2.2_main_description.png?v=1618924523)
The AiM SmartyCam GP HD 2.1 & 2.2 roll cage mount has been designed to securely mount the SmartyCam GP HD 2.1 & 2.2 bullet camera.The roll cage bracket (v-bracket) adjusts using a ball and socket system for optimum positioning and simply clamps to roll bars of a wide range of diameters.
Roll Cage Mount
Includes a handlebar bracket, and a rubber lining to prevent slipping and vibrations.Also, the bullet cam bracket can be positioned for your required viewing.
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Free_Download.png?v=1629297377)
- Handlebar bracket
- 60mm arm
- Ball head
![AiM SmartyCam GP HD Bullet Cam Roll Cage Mount 2.1 & 2.2 - AimShop.com](http://www.aimshop.com/cdn/shop/products/SmartyCamGPHDRollCageMount_1445x.png?v=1593791923)
![AiM SmartyCam GP HD Bullet Cam Roll Cage Mount 2.1 & 2.2 - AimShop.com](http://www.aimshop.com/cdn/shop/products/Smartycam_GP_HD_roll_cage_mount_-_disassembled_1445x.jpg?v=1593791923)
- 選択を選択すると、ページ全体が更新されます。
