AiM SmartyCam GP HD Bullet Cam 2.2 Connection Harness for Motocross
SKU: SM-GP-1-R2-MX
- 通常価格
- £80.00
- 通常価格
- セールスプライス
- £80.00
- 単価
- あたり
AiM SmartyCam Bullet Cam GP HD 2.2 Connection Harness
The AiM SmartyCam 2.2 GP HD connection harness is the cable that is fitted between the recorder box and the bullet camera.
Suitable for SmartyCam 2.2 GP HD | Connection harness |
Use as a replacement or spare |
Suitable for the SmartyCam 2.2 GP HD
Available in 1m, 2m, 3m, 4m
- SmartyCam 2.2 GP HD Connection Harness
- Lead fits between the recorder box and the bullet cam
- Available in 1m, 2m, 3m, 4m
- 1 x SmartyCam 2.2 GP HD Connection Harness
The AiM SmartyCam 2.2 GP HD connection harness is the cable that is fitted between the recorder box and the bullet camera.Key Features :
The AiM SmartyCam 2.2 GP HD connection harness is the cable that is fitted between the recorder box and the bullet camera.Suitable for the SmartyCam 2.2 GP HD
- 選択を選択すると、ページ全体が更新されます。
