AiM MyChron5 Battery Blanking Plate
SKU: M5-BP
- 通常価格
- £15.00
- 通常価格
- セールスプライス
- £15.00
- 単価
- あたり
The AiM blanking plate is required when an external battery is the prefered way to power the AIM Mychron 5.
Suitable for MyChron5 S & MyChron5 S 2T | Prevents water & dirt ingress |
It replaces the battery inside the unit and helps prevent the ingress of water and dirt.
- MyChron Blanking Plate
- 4 x screws
- 1 x MyChron5 Blanking Plate
- 4 x Screws
The AiM blanking plate is required when an external battery is the prefered way to power the AIM Mychron 5.Key Features :
The AiM blanking plate is required when an external battery is the prefered way to power the AIM Mychron 5.It replaces the battery inside the unit and helps prevent the ingress of water and dirt.
- 4 x screws
- 4 x Screws
- 選択を選択すると、ページ全体が更新されます。
