製品情報にスキップ
1 5
Aim MyChron 10mm Under Spark Plug Temperature Sensor with TC Yellow 712 3 Pin Patch Lead
SKU: S-T-CHT-P
通常価格
£115.00
通常価格
セールスプライス
£115.00
注文すべてでカーボンニュートラルな配送
AiM MyChron 10mm Under Spark Plug Temperature Sensor Kart
The AiM 10mm Under Spark Plug is suitable for all MyChrons 4 & 5 S 2T. It is required to measure the cylinder head temperature of your Kart. Also comes with a TC Yellow to 712 3 pin patch lead.
Measure engine temperature TC yellow -712 3 pin patch lead
10mm diameter 2 pin Mignon connection
The AiM 10mm Spark Plug thermocouple temperature sensor is used to measure the cylinder head temperature of your Kart. The sensor should be placed between the spark plug and the cylinder head.
To keep the sensor in contact with the cylinder head, you will need to remove the washer from the plug when installing the thermocouple.
While running the thermocouple along with the Kart chassis, keep it as far as possible from other cables like RPM or Lap Receiver to minimize cable interferences.
This sensor comes with a TC Yellow to 712 3 pin patch lead 1.5m in length.
Temperature range of 0-300°C
Sensor cable length 400mm
  • Temperature working range: 0-3000°C
  • Cable sensor length: 400mm
  • Cable Type: Compensated
  • Two-pin male thermocouple connection
  • K Type thermocouple
  • TC Yellow to 712 3 pin patch lead 1.5m
  • AiM 10mm Under Spark Plug Temperature Sensor
