製品情報にスキップ
1 3
AiM MXP 1.3 6" TFT Suzuki Logger with CAN Connection
SKU: MXP-SUZ-KIT
通常価格
£2,190.00
通常価格
セールスプライス
£2,190.00
注文すべてでカーボンニュートラルな配送
AiM MXP Suzuki Logger with CAN Connection
The MXP Suzuki dash logger has a 6" TFT display which has been designed to acquire and display data coming from the ECU.
6" TFT display GPS Module
CAN output 10 configurable RGB LEDs shift lights
Connecting the MXP dash to your ECU is simple. You can sample dozens of channels straight from the vehicles ECU. This is usually the quickest and easiest setup, needing only a cable connection to the ECU instead of multiple connections and analogue sensors. The sampled data will depend on your actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear, lambda value (air/fuel ratio). The list of available ECU drivers is constantly updated and upgraded and includes approximately 1000+ different  ECUs.
Two Digital Outputs
Flexible Alarms
CAN output
GPS Module
Pin Harness
  • Display: 6" TFT Display
  • CAN connections: 3
  • ECU connection: CAN, RS232 or K-Line to 1,000+ industry-leading ECUs
  • Second CAN: Yes
  • Wi-Fi connection: Yes
    + 3 axis magnetometer
  • Internal Memory: 4 GB
  • Body: Anodized Aluminium
  • Pushbuttons: Metallic
  • Power Consumption: 400mA
  • Weight: 640g
  • MXP Dash Logger
  • 37 Pin standard harness
  • GPS Module with cable
Two Digital Outputs
Flexible Alarms
CAN output
GPS Module
Pin Harness
  • Second CAN: Yes
  • Weight: 640g
  • MXP Dash Logger
