製品情報にスキップ
1 2
AiM IR Optical Lap Receiver 719 Plug 300cm Car
SKU: S-IR-719-30
通常価格
£80.00
通常価格
セールスプライス
£80.00
注文すべてでカーボンニュートラルな配送
The AiM Infrared Receiver is a spare or replacement Receiver that is installed in your race car and receives the lap signal from the infrared transmitter.
Spare / Repalcement Reciver 4 pin 719 connector
The AiM Infrared Receiver sometimes referred to as an Optical Lap Reciever is installed in your race car and receives lap signals from the infrared transmitter positioned at the side of the track. It just needs to be pointed to the side of the track where the transmitter is installed to be able to read the signal.
It is also available with a 4 pin metal plug connector.
The car infrared receiver is available with a 300cm lead, it is also available in a 90cm lead for bikes/kart, although there is nothing stopping you from using the lead that best suits your requirements.
Please Note: The IR Optical Lap Transmitter Beacon is available to purchase in our accessories tab.
Installation
The Infrared receiver should be fixed to your car by fixing through the fixing hole at the top of the receiver. When fixing the receiver be sure that the eye is pointing to the side of the track where the receiver has been installed.
Analyse with Race Studio 3
  • Binder connection Pinout:
  • 1 - n.c
  • 2 - GND
  • 3 - V battery (7-15 VDC)
  • 4 Optical Lap Signal
  • IR Optical Lap Receiver 719 Plug 300cm
Installation
  • 1 - n.c
  • 2 - GND
