AiM 23 Pin Plug And Pins (1.2 Strada MXS, MXP, MXG)
SKU: P-AMP-23-5CND7706802-5CT0770520
- 通常価格
- £38.00
- 通常価格
- セールスプライス
- £38.00
- 単価
- あたり
The AiM 23 pin plug and pins are ideal if you need a replacement or to keep them as spares.
Suitable MX Strada Series 1.2 | 23 pins, One plug |
Ideal for replacement or spares | |
Suitable for MX Series Strada 1.2
- AMP Plug
- 23 Pins
- AiM 23 Pin Plug & Pins for MX Series Strada 1.2
The AiM 23 pin plug and pins are ideal if you need a replacement or to keep them as spares.Key Features :
The AiM 23 pin plug and pins are ideal if you need a replacement or to keep them as spares.Suitable for MX Series Strada 1.2
- AMP Plug
- 23 Pins
- 選択を選択すると、ページ全体が更新されます。
