製品情報にスキップ
1 1
AiM 14 Pin Strada 1.2 OBD11 Harness for MXS, MXG, MXP
SKU: MX-S-L-OBDII-V02573340
通常価格
£160.00
通常価格
セールスプライス
£160.00
注文すべてでカーボンニュートラルな配送
AiM 14 Pin Strada 1.2 OBDII Loom for MXS, MXP, MXG
The AiM 14 pin connector harness is a standard replacement for the Strada MXS, MXP, MXG (MX series) dash displays.
Fits MXS, MXG, MXG dashes Replacement for original wiring
 14 pin AMP female connector 4 pin binder 719 female
 5 pin binder 712 female 16 pin OBDII
14 Pin AMP OBDII Harness
The AiM 14 pin Strada 1.2 AMP connector with OBD11 connector is a standard replacement for the MXS, MXG, MXP (MX Series) dash displays.
With pre-wired connectors for easy connectivity. A 14 pin AMP female connector, 4 pins Binder with 719 female connectors, 5 pins Binder 712 female connector and 3 cables.
AiM 14 Pin Strada 1.2 OBDII Harness for MXS, MXP, MXG
  • 14 pins AMP female flying connector
  • 4 pins Binder 719 female connector
  • 5 pins Binder 712 female connector
  • 16 pins ODB11 flying connector
  • x3 1 x 0.5 cables
  • 14 pin Strada 1.2 OBDII Harness
  • x3 1 x 0.5 cables
