10 Channel Sticker Sheets for Wireless Steering Wheel Plate
SKU: RBI-SS10
- 通常価格
- £30.00
- 通常価格
- セールスプライス
- £30.00
- 単価
- あたり
Customise your Wheel plate
- Rotary Stickers:
- 12 waterproof, 180 microns, vinyl stickers
- Low initial tack with high ultimate adhesion
- Overall sheet dimensions 148mm x 105mm
- 6 larger stickers have a 28mm outer diameter, 10mm inner diameter
- 6 smaller stickers have a 20mm outer diameter, 10mm inner diameter
- 180 motorsport stickers:
- 180 waterproof, 180 microns, vinyl stickers
- Low initial tack with high ultimate adhesive
- Overall sheet dimensions 310mm x 220mm
- Circle stickers have a 12mm internal diameter hole - apply before soldering
- Sausage stickers follow a 12mm diameter curve and can be retro-fitted where the switches are already soldered
- Two sticker sheets for buttons for 10 channel wheel plate. 180 stickers
- One sticker sheet for rotary switches for 10 channel wheel plate. 12 stickers
- Rotary Stickers:
- 選択を選択すると、ページ全体が更新されます。
