1 di 1
Super B Battery Interface Box (BIB) (Nomia & Nomada)
SKU: BIB-12-350
Prezzo regolare
£1,225.00
Prezzo regolare
Prezzo di vendita
£1,225.00
superb lithium batteries
The Battery Interface Box (BIB) is a device capable to connect and disconnect a battery or a battery bank to a load / charger (DC bus) with the intent to protect the Li-ion battery or battery bank against improper use. The BIB communicates with the battery’s BMS (Battery management system) to request to the batteries if they are operable and used within their limits. The BIB is available in various variants: 12V350A, 24V350A, 48V350A, 12V600A, 24V600A and 48V600A.
  • Product Features
    The BIB ensures the following functions:
  • Collecting the status and alarm messages of all the Li-ion batteries connected. In case of an alarm in one of the batteries, the BIB will disconnect the battery (bank) by opening the main relay
  • Scanning the CAN bus to see if all the batteries it expects are present. In case of a missing battery, the BIB will disconnect the battery (bank) by opening the main relay.
  • Collecting information of all Li-ion batteries in the battery bank and presenting it as one battery
  • Programmable power down on user adjustable battery (bank) SoC level.
  • Programmable Auto-On function
  • Up to sixteen batteries can be connected to the BIB without external CAN power. (With the 12V BIB versions, external CAN power is always necessary.)
  • Up to 100 Li-ion batteries can be connected to the BIB with use of external CAN power
  • Pre-charge as startup sequence to prevent inrush currents
  • Real time clock for accurate time stamped function, statistics and error logging
  • The BIB is a standalone device
  • The BIB can be configured using a CAN-USB converter and the battery monitor software
Intended Use
The Battery Interface Box (BIB) is intended to use as a disconnect device for protecting batteries against misuse. Potential applications of the BIB include: off grid power supply, marine power supply, industrial power supply and (renewable) energy storage. The BIB may not be used in medical and aviation related applications.
CONNECTING THE BATTERY INTERFACE BOX (BIB)
  • Product Features
Intended Use
Specifications
PRODUCT SPECIFICATIONS
Dimensions (LxWxH)
180 x 254 x 111 mm / 7.08” x 10” x 4.37”
Case material
PC
Ingress protection
IP 54
Certifications
CE
Supply voltage
7.5 V - 16 V (SB BIB LV12V350-600A) | 7.5 V - 32 V (SB BIB LV24V350A-600A) | 15 V - 64 V (SB BIB LV48V350A-600A)
Rated current
350A or 600A
Precharge resistor value
1 ohm (SB BIB LV12V350-600A) | 4 ohm (SB BIB LV24V350A-600A) | 16 ohm (SB BIB LV48V350A-600A)
Voltage difference across main relay to turn-on
1.25 V (SB BIB LV12V350-600A) | 2.5 V (SB BIB LV24V350A-600A) | 5 V (SB BIB LV48V350A-600A)
Consumption in OFF-state
100 mA
Consumption on standby
330 mA (SB BIB LV12V350) | 197 mA (SB BIB LV24V350A) | 142 mA (SB BIB LV48V350A) | 740 mA (SB BIB LV12V600A) | 420 mA (SB BIB LV24V600A) | 260 mA (SB BIB LV48V600A)
Recommended operating Temp
-20°C to 45°C / -4°F to 113°F
Recommended storage temperature
-10°C to 20°C / 14°F to 68°F
Relative humidity
10-90%
Quickstart Guide
Available to download Here
Mobile App
superb app
