LiveU Solo PRO Connect 2 Modem Kit
SKU: LU-SOLO-LRTC-KIT-02-EA
- Prezzo regolare
- £390.00
- Prezzo regolare
- Prezzo di vendita
- £390.00
- Prezzo unitario
Add modems that inherently support multiple mobile providers and provide a complete hassle-free solution for use with your Solo PRO using this LiveU Solo PRO Connect 2 Modem Kit. This kit uses high-quality USB modems from LiveU Net with integrated high-gain antennas and ensures robust performance and reliability using LiveU's managed SIM cards, which enable compatibility with all LiveU units and support LiveU Reliable Transport (LRT), available via separately sold, monthly or annual cloud subscriptions.
Features of the LiveU Solo PRO Connect 2 Modem Kit
- Two LU Net 4G Modems: Provides access to multiple networks for enhanced reliability and bandwidth.
- Two SIM Cards: Corresponding SIM cards ensure seamless integration with the LU Net 4G modems.
- Peak download speed: 600 Mb/s
- Peak upload speed: 150 Mb/s
- Colour: black
- Compatibility: LiveU Solo PRO
- USB I/O: 1 x USB-A 2.0 Integrated Male Input/Output
- Connectivity: Supported Bands: LTE: B1, B2, B3, B4, B5, B7, B8, B9, B12, B13, B18, B19, B20, B26, B28, B29, B30, B32, B41, B42, B43, B46, B48, B66 3G/4G: B1, B2, B4, B5, B6, B8, B9, B19
- Data Transfer Rate: Peak Download: 600 Mb/s Peak Upload: 150 Mb/s
- Card Slot: Micro SIM
- Wireless: 4G / 5G *Built-In
- x2 LU Net 4G
- x2 Sims
- x1 Y Cable HDMI Extension Cable
Add modems that inherently support multiple mobile providers and provide a complete hassle-free solution for use with your Solo PRO using this LiveU Solo PRO Connect 2 Modem Kit. This kit uses high-quality USB modems from LiveU Net with integrated high-gain antennas and ensures robust performance and reliability using LiveU's managed SIM cards, which enable compatibility with all LiveU units and support LiveU Reliable Transport (LRT), available via separately sold, monthly or annual cloud subscriptions.Features of the LiveU Solo PRO Connect 2 Modem Kit
- Colour: black
- x2 LU Net 4G
- x2 Sims
