Link Three Channel Inductive Igniter - I3
SKU: I3
- Prezzo regolare
- £132.00
- Prezzo regolare
- Prezzo di vendita
- £132.00
- Prezzo unitario
This three-channel igniter is suitable for electronic ignition applications. Required when using coils that don't have inbuilt igniters.
Common uses include wasted spark on 6 cylinder engines, coil-per-plug setups on 3 cylinder engines or using multiple igniters for 6 and 8 cylinder set-ups.
Compatible with all Link Wire-in ECU’s.
Includes heatsinking compound, 7 pin plug, pins and boot.
Note - Does not include heatsink
- Three Channel Igniter
- 7 pins pin plug, pins and boot
This three-channel igniter is suitable for electronic ignition applications. Required when using coils that don't have inbuilt igniters.Common uses include wasted spark on 6 cylinder engines, coil-per-plug setups on 3 cylinder engines or using multiple igniters for 6 and 8 cylinder set-ups.
