Link Field Installable CAN Plug
SKU: CANF
- Prezzo regolare
- £18.00
- Prezzo regolare
- Prezzo di vendita
- £18.00
- Prezzo unitario
Link Plug (CANF)
Required to add CAN/Serial communications to G4+/G4X Plugin ECU’s. Plugs directly into ECU PCB header. Use the Link CANF connector (purchased separately) to connect.
- Field Installable CAN Plug
Link Plug (CANF)
Required to add CAN/Serial communications to G4+/G4X Plugin ECU’s. Plugs directly into ECU PCB header. Use the Link CANF connector (purchased separately) to connect.What's in The Box
