Link Pin Kit "B" #TKB
SKU: TKB
- Prezzo regolare
- £35.00
- Prezzo regolare
- Prezzo di vendita
- £35.00
- Prezzo unitario
Pin Kit "B" All WireIn ECUs, not required for Atom
Equivalent plug and connectors as "B" Loom. Plug and Pin Kit only.
Suitable for:
Link G4X Storm (Loom A/Pin Kit A also required)
Link G4X and G4+ Fury (Loom A/Pin Kit A also required)
Link G4X, G4+ and G4 Xtreme (Loom A/Pin Kit A also required)
Link G4+ Thunder (Note: Loom A/Pin Kit A and connector kits C and D may also be required)
Link G4+ Storm Black (Loom A/Pin Kit A also required) – Note: Loom B is not required for the older Silver or Blue G4 or G4+ Storm models
Vipec V88 (Loom A/Pin Kit A also required)
Vipec i88 (Loom A/Pin Kit A also required)
- Plug & Pins - Pin Kit "B"
Pin Kit "B" All WireIn ECUs, not required for AtomEquivalent plug and connectors as "B" Loom. Plug and Pin Kit only.
Suitable for:
Link G4X Storm (Loom A/Pin Kit A also required)Link G4X and G4+ Fury (Loom A/Pin Kit A also required)
