Link "A" Loom Short - #OLA
SKU: OLA
- Prezzo regolare
- £67.00
- Prezzo regolare
- Prezzo di vendita
- £67.00
- Prezzo unitario
Link A Loom Short 0.4m - #OLA
Loom "A" 400mm WireIn ECUs
0.4m long 'A' loom to suit G4, G4+ and G4X Wire-In ECUs
Perfect for all custom wiring jobs utilising Link WireIn ECUs. The ‘A’ Loom has a Link ‘A’ ECU connector at one end and unterminated wires at the other. All wires are colour coded to match the manual. This loom is also available in 2.5m and 5m lengths.
Suitable Applications:
All Link G4X WireIn ECU’s (Note: Loom B will also be required for the Storm/Fury/Xtreme)
Link G4+ Atom (NB: Does NOT suit the earlier G4 Atom models. I.e. G4+ only)
Link G4+ Atom II
Link G4+ Monsoon
Link G4 Storm
Link G4+ Storm Blue
Link G4+ Storm Black (Note: Loom B will also be required)
Link G4 RX
Link G4+ Fury (Note: Loom B will also be required)
Link G4 Xtreme (Note: Loom B will also be required)
Link G4+ Xtreme (Note: Loom B will also be required)
Link G4+ Thunder (Note: Loom B and connector kits C and D may also be required)
Vipec V44
Vipec i44
Vipec V88 (Note: Loom B will also be required)
Vipec i88 (Note: Loom B will also be required)
Link A Loom Short - #OLA
- "A" Loom Short 0.4m
Loom "A" 400mm WireIn ECUs0.4m long 'A' loom to suit G4, G4+ and G4X Wire-In ECUs
All Link G4X WireIn ECU’s (Note: Loom B will also be required for the Storm/Fury/Xtreme)Link G4+ Atom (NB: Does NOT suit the earlier G4 Atom models. I.e. G4+ only)
Link G4+ Atom II
Link G4+ Monsoon
Link G4 Storm
Link G4+ Storm Blue
Link G4 RX
Vipec V44
Vipec i44
