Kawasaki ZX-10R AiM Solo 2 DL Motorcycle Cable & Bracket
SKU: KAW-PP-KAW-B
- Prezzo regolare
- £120.00
- Prezzo regolare
- Prezzo di vendita
- £120.00
- Prezzo unitario
The AiM Kawasaki motorcycle cable & bracket set has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 DL GPS Lap Timers.
Kawasaki cable & bracket | 7 pin - 712 male binder connection |
Kawasaki Solo 2 DL Cable & Bracket
The AiM ECU plug & play cable has been specifically designed for the Kawasaki bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged.
The AiM Kawasaki bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike.
Please Note: For Kawasaki models From 2016.
The plug & play cable currently fits the following Kawasaki bike models:
Kawasaki Ninja ZX-10R MY2011 - 2001-2015 | Kawasaki Ninja ZX-10R MY2011 Racing Kit - 2011-2015 |
Example data protocols
- Specifically designed Kawasaki Plug & play cable and bracket for the Solo 2 DL
- Below is the pinout drawing for the Kawasaki plug & play connection cable.
- Kawasaki plug & play connection cable
- 1 bracket
- 2 toothed washers
- 2 Allen screws M6 x 12mm
The AiM Kawasaki motorcycle cable & bracket set has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 DL GPS Lap Timers.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Kawasaki bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged.The AiM Kawasaki bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike.
The plug & play cable currently fits the following Kawasaki bike models:Kawasaki Ninja ZX-10R MY2011 - 2001-2015 | Kawasaki Ninja ZX-10R MY2011 Racing Kit - 2011-2015 |
- 1 bracket
- 2 toothed washers
