Honda AiM Solo 2 DL Motocross Plug & Play Lap Timer Kit
SKU: SOLO2-K-HON-MX-PP
- Prezzo regolare
- £535.00
- Prezzo regolare
- Prezzo di vendita
- £535.00
- Prezzo unitario
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for Honda bikes this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide | Honda ECU connection cable |
This kit has been specifically designed for Honda bikes. The kit comes with a cable for your bike. Connecting the Solo 2 DL to your bike's ECU will give you all the engine performance information you need to help improve your driving performance.
Honda CRF 250cc - From 2010 onwards | Honda CRF 450cc - From 2009 onwards |
The Honda ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Data Recall On Screen
- Display: Graphical
- GPS: 10 Hz
- External power: 12 V
- Memory: 4 GB
Below is the pinout drawing for the Honda plug & play connection cable.
- Solo 2 DL
- Power cable with AC adapter
- User manual
- AiM Honda Connection Cable
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for Honda bikes this kit will ensure an improvement in your driving performance.Key Features :
This kit has been specifically designed for Honda bikes. The kit comes with a cable for your bike. Connecting the Solo 2 DL to your bike's ECU will give you all the engine performance information you need to help improve your driving performance.Plug & Play
The plug & play cable currently fits the following Honda bike models:Honda CRF 250cc - From 2010 onwards | Honda CRF 450cc - From 2009 onwards |
The Honda ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.The sampled data you record depends on the actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel). The list of ECUs is forever growing and being updated.
With Race Studio 3 you can also analyse all data recorded by Solo 2 DL and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances.Technical
- GPS: 10 Hz
- Memory: 4 GB
- Solo 2 DL
- User manual
