1 di 4
Dyn X Professional Racing Simulator
SKU: CM-DYNX-C
Prezzo regolare
£1,495.00
Prezzo regolare
Prezzo di vendita
£1,495.00
+ IVA (solo Regno Unito)
Powered by Shopify Planet
dyn x racing simulator
DYN X DYNAMIC RACING EXPERIENCE
Precision-engineered for a genuinely authentic racing experience
The Dyn X exemplifies Cooler Master's commitment to innovation, marrying form and function in a sleek package. Precisely dial in your driving position with a single adjustment—perfectly adaptable for a wide range of racing styles such as Formula, GT, NASCAR, Rally, Trophy Truck, and more. This is more than just a gaming rig—it's a pro-level racing simulator that invites you to experience real-to-life immersion at its finest. Step into the Dyn X and feel the pulse of professional racing from the comfort of your own home.
dyn x
UNRIVALED FLEXIBILITY
One single adjustment offers 14 diverse driving positions: Formula, GT, Rally, NASCAR, Trophy Truck, Semi Truck, and more. The Dyn X adapts to your personal simulation needs.
dyn x
PRESONALISED EXPERIENCE
Fine-tune your experience to perfection.
Compatible with a broad array of racing accessories and effortless to adjust, Dyn X offers an exceptional level of customization. Fine-tune your experience to perfection.
dyn x
LONG-LASTING COMFORT
Built with a rigid structure that doesn't compromise ergonomics, the Dyn X keeps you focused and comfortable, even during prolonged racing sessions.
dyn x Racing simulator
All-Around Professional Racing Simulator
Embrace a new dimension of sim racing with the Dyn X from Cooler Master. This isn't your everyday setup; it's a rigorously designed system for passionate racing enthusiasts who relish the thrill of the track in both real and virtual worlds. The Dyn X is engineered to fuel your need for speed and revolutionize your professional simulation environment.
Optional Extras
DYN X RACING SEAT
Ignite your virtual racing journey with the Dyn X Racing Seat. This is not simply a seat it's your entryway to the fast paced world of the most challenging global racetracks.
racing chair
DYN X TRAY MOUNT
The Dyn X Side Mount and Tray Mount are designed to widen the Dyn X cockpit compatibility with even more brands and models of steering wheel base, providing users with more flexibility to choose their own preferences and fulfill their needs for an exceptional level of customization and personalized experience.
racing chair
Component 1Dyn X - Cockpit
Component 2Dyn X - Racing Seat
Ergonomics Group5 - 99th Percentile Men
Assembled Dimensions (Upmost Position)1707mm x 756mm x 1044mm (LxWxH)
Assembled Dimensions (Downmost Position)1591mm x 756mm x 998mm (LxWxH)
Ready for Motion Actuator SystemYes
Buttkicker MountYes
Included Steering Wheel MountFront Mount
Number of Driving Positions14
Frame Tubing MaterialSteel (JIS STKM 13A)
Frame Tubing Diameter50.8mm
Frame Tubing Wall Thickness2mm
Gusset Thickness5mm
Steering Wheel Mount Material (All Mounts)Steel
Steering Wheel Mount Material Thickness (All Mounts)6mm
Pedal Tray MaterialAluminum (5052)
Pedal Tray Material Thickness5mm
Seat Mount MaterialSteel
Seat Mount Material Thickness3mm
Steering Wheel Slide (Forward/Back)300mm
Steering Wheel Mounting Positions (Front & Side Mount)6 (3 regular + 3 with mount inverted)
Steering Wheel Mount Degrees of Adjustment (Front & Side Mount)Position 1: 50°, Position 2: 47°, Position 3: 44°, Total: 80° (regular + inverted)
Steering Wheel Mount Height Adjustment (Front & Side Mount)81mm (6 positions)
Steering Wheel Mounting Positions (Tray Mount)4 (2 regular + 2 with mount inverted)
Steering Wheel Mount Degrees of Adjustment (Tray Mount)Position 1: 26°, Position 2: 24°, Total: 60° (regular + inverted)
Steering Wheel Mount Height Adjustment (Tray Mount)140mm (4 positions)
Pedal Tray Slide (Forward/Back)400mm
Pedal Tray Tilt (Up/Down) ± 45°
Pedal Tray Lift (Up/Down)±100mm
Seat Slide (Forward/Backward)150mm
Seat Tilt (Up/Down)3 - 27°
Seat Lift (Up/Down)30mm
Number of Frame Tilt Positions14
Frame Tilt3 - 22°
Combined Frame/Seat Tilt6 - 49°
Seat Shell MaterialFiberglass Reinforced Plastic (FRP)
Seat Fabric MaterialPremium Synthetic Suede (Eco-suede)
Seat PaddingMulti-density Foam / Shock-absorbent Foam
Harness Slots5
HeadrestDetachable and Adjustable
Component 3Dyn X - Steering Wheel Mounts - Side Mount
Component 4Dyn X - Steering Wheel Mounts - Tray Mount
Side Mount - Supported Mounting StyleSide-mounted
Side Mount - Material6mm mild steel plate
Side Mount - Dimensions132.3mm x 135.5mm x 234.4mm
Side Mount - Degrees of AdjustmentPosition 1: 50°, Position 2: 47°, Position 3: 44°, Total: 80° (regular + inverted)
Side Mount - Height Adjustment81mm (6 positions)
Tray Mount - Supported Mounting StyleDesk-mounted
Tray Mount - Material6mm mild steel plate
Tray Mount - Dimensions435.6mm x 106.2mm x 249.0mm
Tray Mount - Degrees of AdjustmentPosition 1: 26°, Position 2: 24°, Total: 60° (regular + inverted)
Tray Mount - Height Adjustment140mm (4 positions)
Product NumberIXM-DX1-K-NN-1 (Cockpit)
Product NumberIXM-RS1-KB-NN-1 (Racing Seat)
Product NumberIXM-WM1-KS-NN-1 (Side Mount)
Product NumberIXM-WM1-KT-NN-1 (Tray Mount)
dyn x
dyn x
dyn x
Optional Extras
DYN X RACING SEAT
racing chair
DYN X TRAY MOUNT
racing chair
Buttkicker MountYes
Gusset Thickness5mm
Frame Tilt3 - 22°
Harness Slots5
