1 di 1
Ducati Panigale AiM Solo 2 & Solo 2 DL Motorcycle Bracket
SKU: DUC-1-B
Prezzo regolare
£60.00
Prezzo regolare
Prezzo di vendita
£60.00
The AiM Ducati Panigale motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.
Ducati Panigale bracket All necessary mounting hardware
Suitable for Solo 2 & Solo 2 DL
Ducati Panigale Solo 2 & Solo 2 DL Bracket
The Ducati Panigale bracket has been designed to provide a simple and secure way for mounting your Solo 2 or Solo 2 DL GPS Lap Timer on to your bike.
Please Note: If you are unsure this bracket will fit your bike, don't hesitate to contact one of our team. Either by email, phone or online chat.
Also available is our Ducati Panigale plug & play cable for the following bike models: (Sold Separately)
899 Panigale - 2013-2015 959 Panigale - From 2016
1199 Panigale - 2012-2014 1199R Panigale - 2015-2017
1299 Panigale - 2015-2019 Panigale V4 - From 2018
Panigale V2 - From 2020
Example data protocols
  • Specifically designed Ducati Panigale 899, 959, 1199, 1199R, 1299, V4, V2 bracket for the Solo 2 and Solo 2 DL
  • 1 Bracket
  • 1 washer
  • 1 rubber dowel
  • 1 Bracket
  • 1 washer
  • 1 rubber dowel
