Ducati Multistrada 1200 AiM Solo 2 DL & SmartyCam 3 GP Motorcycle Plug & Play Lap Timer Track Day Kit
SKU: SOLO2-K-DUC-3-SM-CAM-GP-2-SM-GPC
- Prezzo regolare
- £2,210.00
- Prezzo regolare
- Prezzo di vendita
- £2,210.00
- Prezzo unitario
The Ducati Multistrada plug & play kit combined with the Solo 2 DL and SmartyCam 3 GP gives you the ultimate track day experience.
Database with more than 4,000 tracks worldwide | Ducati Multistrada ECU connection cable |
This ultimate track day kit has been specifically designed for the Ducati Multistrada bike. The kit includes a plug & play interface cable for your bike. A Solo 2 DL to give you the most precise lap times and the incredibly robust SmartyCam 3 GP to record your races and provide all the technical layovers to help improve your performance. Also added is our 3 GP bullet camera clamp mount to enable you to position the bullet camera on your bike. Connecting the Solo 2 DL to your Ducati Multistrada ECU will give you all the engine performance information you need to help improve your driving performance.
SmartyCam 3 GP Features:
The plug & play cable currently fits the following Ducati Multistrada bike model:
Multistrada 1200 - 2010-2011 |
Powerful Combination
The Ducati Multistrada ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
SmartyCam 3 GP
Automatic Start/Stop
- Display: Graphical
- GPS: 10 Hz
- External power: 12 V
- Memory: 4 GB
- SmartyCam GP HD 2.2
- CMOS sensor: Global Shutter
- Video Out: 3G-SDI
- External power: 9-15 Volt
- Auto Power ON: Yes
- Auto Power OFF: Yes
- Body: Anodised Aluminium
Below is the pinout drawing for the Ducati Multistrada plug & Play connection cable.
- Solo 2 DL
- Power cable with AC adapter
- SmartyCam 3 GP - Bullet Cam
- External CAN cable 2m
- External power cable
- Ducati Multistrada Plug & Play connection cable
The Ducati Multistrada plug & play kit combined with the Solo 2 DL and SmartyCam 3 GP gives you the ultimate track day experience.Key Features :
This ultimate track day kit has been specifically designed for the Ducati Multistrada bike. The kit includes a plug & play interface cable for your bike. A Solo 2 DL to give you the most precise lap times and the incredibly robust SmartyCam 3 GP to record your races and provide all the technical layovers to help improve your performance. Also added is our 3 GP bullet camera clamp mount to enable you to position the bullet camera on your bike. Connecting the Solo 2 DL to your Ducati Multistrada ECU will give you all the engine performance information you need to help improve your driving performance.SmartyCam 3 GP Features:
The plug & play cable currently fits the following Ducati Multistrada bike model:Multistrada 1200 - 2010-2011 |
The Ducati Multistrada ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.The sampled data you record depends on the actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel). The list of ECUs is forever growing and being updated.
SmartyCam 3 GP
- GPS: 10 Hz
- Memory: 4 GB
- Video Out: 3G-SDI
- Solo 2 DL
