1 di 12
Auto Marine Superseal Plug with Seal & Pins Female & Male
SKU: P-SS-1-F
Prezzo regolare
£1.25
Prezzo regolare
Prezzo di vendita
£1.25
Auto Marine's Super Seal Connectors are a range of compact, high-quality connectors with a water-resistant joint.
Male or Female plug available Pins and seals
Water-resistant joint Suits cables with 0.5mm to 1.5mm cross-section
Auto Marine's Super Seal Connectors are a range of compact, high-quality connectors with a water-resistant joint. Suitable for cables with a cross-section area of 0.5mm to 1.5mm (approx 20 amps max), they are ideal for applications that require a sure-fitting, weatherproof connector.
Available in male and female options to allow multiple connectors of the same side to be applied (e.g. various types of ends to plug onto a battery charger).
Available in 1, 2, 3, 4, 5, and 6-way, Male and Female options
  • Plug housing for receptacle contacts, cap housings and tab contact varients
  • Silicone rubber seals
  • Suitable for powertrain, security and body & chassis systems
  • Male & Female available
  • 1, 2, 3, 4, 5 ,6 Pin available
  • Auto Marine Super Seal Plug with pin and seals
