AiM Brake Pressure Sensor M10 0-100 Bar Kart
SKU: S-P-B-M10-X05PSA00100B10-K
- Prezzo regolare
- £190.00
- Prezzo regolare
- Prezzo di vendita
- £190.00
- Prezzo unitario
+ IVA (solo Regno Unito)
The AiM M10 0-100 Bar pressure sensor is suitable for oil and fuel pressure readings and can read pressures up to 100 bars. This sensor will monitor brake pressure levels for optimum performance accurately.
M10 - 0-100 Bar | 4 pins 719 male binder |
The AiM M10 - 0-100 Bar brake pressure sensors are fitted with male four pins black 719 binder plug connections to suit all AIM loggers and dash display/loggers.
Whether your kart is equipped with single, dual, fixed or adjustable master cylinders, adding brake pressure sensors allow you to monitor brake performance, make real changes and identify issues quickly and precisely.
Suitable for use with the MyChron4, MyChron5, MyChron4 2T, MyChron5 2T, MyChron5 S, MyChron5 S 2T Kart Dash / Data Loggers.
You will require a 712-719 patch lead to be able to connect the sensor to the MyChron Expansion box, via the data hub.
Below shows how you can expand your system to help enhance your racing performance.
![](https://cdn.shopify.com/s/files/1/0214/9392/files/AiM_Brake_Pressure_Sensor_M10_0-100_Bar_Kart_expand_your_system.png?v=1624538604)
- Supply: 8-16V
- Characterisation: 500 mV/ 0 bar 4500 mV/ 100 bar
- Consumption: < 10 mA
- Sealing: IP66
- Weight: 30g
- Cable Length: 400mm
- Thread: M10
- AiM Brake Pressure Sensor M10 - 0-10 Bar
The AiM M10 0-100 Bar pressure sensor is suitable for oil and fuel pressure readings and can read pressures up to 100 bars. This sensor will monitor brake pressure levels for optimum performance accurately.Key Features :
![](https://cdn.shopify.com/s/files/1/0214/9392/files/AiM_Brake_Pressure_Sensor_M10_0-100_Bar_main_image.png?v=1624454412)
The AiM M10 - 0-100 Bar brake pressure sensors are fitted with male four pins black 719 binder plug connections to suit all AIM loggers and dash display/loggers.Whether your kart is equipped with single, dual, fixed or adjustable master cylinders, adding brake pressure sensors allow you to monitor brake performance, make real changes and identify issues quickly and precisely.
Suitable for use with the MyChron4, MyChron5, MyChron4 2T, MyChron5 2T, MyChron5 S, MyChron5 S 2T Kart Dash / Data Loggers.You will require a 712-719 patch lead to be able to connect the sensor to the MyChron Expansion box, via the data hub.
- Supply: 8-16V
- Sealing: IP66
- Weight: 30g
- Thread: M10
![AiM Brake Pressure Sensor M10 0-100 Bar Kart - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMBrakePressureSensorM100-100Bar_9cf4d2e5-8f2b-4c21-bab8-5623f14e2f3e_1445x.png?v=1624537593)
![AiM Brake Pressure Sensor M10 0-100 Bar Kart - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMBrakePressureSensorM100-100Bar_770cfe8d-ba67-4375-99bf-1da515acdefa_1445x.png?v=1624537593)
![AiM Brake Pressure Sensor M10 0-100 Bar Kart - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMBrakePressureSensorM100-100Bar2_8f771c60-c032-4ebb-93f2-08a9fc167762_1445x.png?v=1624537593)
![AiM Brake Pressure Sensor M10 0-100 Bar Kart - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMBrakePressureSensorM100-100Bar3_e0bba190-33a5-484e-bc2a-7f37b2f62d69_1445x.png?v=1624537593)
